Something is Right with My SSD
Discussion in 'SSD Benchmark Locker' started by SamiHAlTer, Jan 21, 2015.
  1. SamiHAlTer
    SamiHAlTer New Member
    3
    Hello!
    I have a Samsung 840 Evo 500 GB SSD. Usually I get Scores of around 200-500 MBps for both read and write tests. I used Samsung Magician to run the tests. I was checking some SSDs on userbenchmark.com, and thought I might as well download their benchmarking software mainly to compare my SSD to the scores they have on their website.
    This is the SSD result for the first benchmark test:
    And for further evidence, here's the link to the test:
    http://www.userbenchmark.com/UserRun/142583
    I thought the software glitched somehow, so I figured I should run the test again:
    I closed every other running software to improve my CPU and graphic cards score, but apparently it even improved the SSD's score. Here is the link for the test:
    http://www.userbenchmark.com/UserRun/142586
    Then, I thought the software itself is bogus, and to confirm that I ran the test on Samsung Magician which used to give me less than 500 MBps on both read and write speeds. To my surprise, even Samsung Magician showed similar results:
    To make sure I'm not going crazy, I looked at the history of Samsung Magician, and I was right. something did change with the SSD's benchmark results:
    I even restarted my PC, and re-ran Samsung's test. Again, similar results:
    ___________________________________________________________________________
    Now, my question is, can anyone explain why I am getting these results? Is there a better way/ software (free, please) that I can use to get accurate results?
  2. The SSD Guy
    852
    Can I ask you to post typical benchmarks like AS SSD, Crystal Diskmark or Anvil? Thanks ahead...
  3. SamiHAlTer
    3
    Other Benchmark Softwares
    Here's the AS-SSD Benchmark results:
    And Atto-Benchmark32:
    Both are showing similar results.
  4. SamiHAlTer
    3
    Found the Cuplrit
    Apparently, the reason for the bogus results is Samsung's RAPID Mode. It is usually Called Ram Cached drive, as seen in the first picture in the Userbenchmark image I posted at the beginning of the thread. I didn't figure this by myself, rather it was someone on another forum where I posted the same thread.
    Here's AS-SSD benchmark results after I disabled RAPID Mode:
    And here's Userbenchmark results. Just skip to the Drive section:
    http://www.userbenchmark.com/UserRun/143178
  5. Zayn
    Zayn New Member
    4
    India
    Samsung's rapid mode is a **** head. As-SSD results are intentionally modified by it.
    Regards,
    Zayn
    VMate 9Apps Lucky Patcher
  6. Chinmoy Pratim Borah
    Chinmoy Pratim Borah New Member
    India
  7. shelialx60
    shelialx60 New Member
    23
    Detroit Pistons
