Kingston Firmware 5.0.3
Discussion in 'Kingston' started by SmogHog, Aug 25, 2012.
  1. SmogHog
    SmogHog Guest
  2. scajjr2
    scajjr2 Guest
    I put my HyperX 120Gb in a build I'm doing (it's been sitting around ever since I upgraded my systems to Samsung 830's) and installed this toolbox but can't find anyway in it to update the firmware.
    Sam
  3. renosablast
    renosablast Guest
  4. scajjr2
    scajjr2 Guest
    Thanks. Is giving a fatal error message when i try to update (from 332abff0) 00000057 is the code.
    Sam
    ---------- Post added at 10:55 AM ---------- Previous post was at 10:49 AM ----------
    nevr mind. Found that this system had the AMD AHCI driver, switched to Microsoft's and it updated. Any issues if I switch back to the AMD driver or should I leave it with the MS one? Board is a Biostar A75MH.
    Sam
  5. renosablast
    renosablast Guest
    If you are using a single drive, the Microsoft default driver is probably fine to use. If you were using two (or more) of these drives in a RAID array utilizing the motherboard's RAID option, then you would need to use the AMD ones.
  6. ratin
    ratin New Member
    iran
