Help: Installing A Modded (Unlocked?) BIOS
Discussion in 'Hardware' started by mlauzon, Feb 9, 2013.
  1. mlauzon
    mlauzon Guest
    I am looking to install the Insyde 1.12 Unlocked BIOS for my Acer Aspire V3-771G, I currently have the stock version of the Insyde 1.12 BIOS installed, so I am unsure if I can actually install what amounts to the same BIOS, although unlocked, over it.
    The stock BIOS can be installed directly from within Windows and also has a DOS installer as well, but I am not sure about the unlocked BIOS. Here is a screenshot of the files within the zip file for the unlocked BIOS:
    [​IMG]
    The BIOS itself can be found for download here:
    https://dl.dropbox.com/u/24459764/Acer_Aspire_V3-771G_Unlocked.zip
    There are no instructions in the zip archive, which I think is just stupid!
    Can anyone give me an idea of how to do this, because I assume there are people here who have installed unlocked BIOS in their PCs before?
  2. OS-Wiz
    OS-Wiz Guest
    I guess the first question one must ask is how you think the "unlocked" will help? To do what?
    If done correctly, during a BIOS flash the BIOS CMOS chip is first completed wiped, then the "new" BIOS is flashed in.
  3. renosablast
    renosablast Guest
    This is generally not a good idea. Manufacturers occasionally update their BIOS to resolve functionality and compatibility issues. Using what would amount to a bootleg BIOS version would likely render it non-updateable. Too much of any PC or laptop's usability relies on a dependable BIOS to gamble on a non-approved version. That's my opinion, but you will likely find it to be the prevalent one.
  4. shelialx60
    shelialx60 New Member
    23
    Detroit Pistons
    Sexy photo galleries, daily updated collections
    http://lesbianism.allproblog.com/?avery
    manta porn urban porn source free xxx tia cherry the porn star watch amateur porn star killer 2 save sites porn
